Anyone welded a 14bff Gov-Lok?
TrcksR4ME
Seattle, WA 98103
I would assume it is possible but wondering if it has been done with any success by anyone else. Anybody have any info on this, anything at all? TIA
I have welded one, Jethro style, and it works fine.
Take it apart, tack it together halfway inside the case, then make little welds at every contact point, install your ball of traction and you're good to go.
I put all the clutches back in just to take up the space even though they weren't doing anything.
[ QUOTE ]
... ball of traction ...
[/ QUOTE ]
/forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
cool, don't even know what it looks like inside a gov-lok, but since I drive the truck very seldon I might as well have the traction the times I do. How long have you runs yours like this?
Mine has a detroit in it (and is a trailer queen anyway). The one I welded up was a trail only vehicle that will never see the road.
Sorry if you got the wrong idea.
no biggie, mine is mostly driven off-road these days, though I have to drive it there. Not to worried about the negative aspects of street driving with it being a spool, as long as it holds up.
As long as you weld it correctly you will break the axleshafts long before you break the carrier or your welds.
We patched up Tim's (Butch - 4x4 Iron) this last week end. IIRC, he said had been beating on it for 7? years before it broke. He had welded the spiders and side gears together into the basket side of the carrier and left the side gear loose on the ring side to simplify alignment. And it is a Gov-Lock carrier. Anyway, after years of beating on it all that time, he finally sheared every single tooth off the side gear trying to get up the same waterfall I broke attempting. So, Saturday night we sat in the parking lot and dismantled that sucker, he borrowed a welder and welded what was left of the side gear to the rest of the mass of stuff, and as far as I know, finished the week end on it. However, he has a Detroit he's planning on installing ASAP (into a different carrier)...
