anyone wheel' a 292 6cyl?
Don't just turn your machine shop loose on your motor build as far as performance - the person in charge might be a fantastic machinest but not much on parts selection.
Stick to the basic's of a solid motor build :
* Long stroke - the 292 already has a 4.120" stroke ( and there is no room for any increase in length - that is the reason for the offset motor mount/fuel pump cam lobe locations ).
* proper intake/exhaust for your RPM range
* Cam grind with as much lift as offered with mild duration
* build as much cylinder/cranking pressure as possible . Custom pistons are real high dollar ( I went with a LPG piston for higher comp rating ) , or you could use a cylinder head off of a early 194 motor that has much smaller chambers ( U2slow- suggested this earlier in the thread ) .
Let the machine shop inspect everything and make sure that you are building a good core to begin with. Do not worry about larger valves and head work at this point . The O.E.M. head has great velocity at extreme low end but is just not a huge air mover for anything much over a truck motor.
I could bore you to death on what all I did on my 292 build so if more info is wanted just let me know .....
HTH's Tom
HTH's Tom
I, for one, would love to be bored to death by your post Tom.:p:
I always enjoy the tech you add to this forum.
I had no idea there were other in-line six cylinder closet freaks out there ! I could take some pic's and post up but it might take me a little while to do so - work is demanding at this time.......
Thanks for the kind words fella's !
Tom
You should look for a diesel. My buddy built a diesel IH scout 192 (I think) and it got 25 mpg before it was broke in hauling a heavy scout around.:eek1:
You can play with your 6s all you want. I have been ther, and done that, Even got the tee shirt.............6=8
All is i can say is I went from inline 6s back to to a V8s for three reasons:
More power
Cheaper to Build
Better MPG
V8s are fule injected ofcourse,
If I ever build another inline it will be another FId engne. IMHO that is the only way to go with an inline. other wise you are better off with a V8. Just my informed and tested opinion.
