Anyone with a 770 cfm Truck Avenger
crazyrc
Northern Alberta, Canada
If anyone is runing the 770 cfm version of the holley, could you tell me where or how you supply vacuum to your brake booster. My 670 had a provision for the brake booster. (about 3/8") My 770 has no such hookup...please inform. /forums/images/graemlins/confused.gif
[ QUOTE ]
[/ QUOTE ]Isn't there a vacume port on the rear of your intake manifold ?? If not, you could always get a carb spacer with a vacume port..... Just a thought.
[ QUOTE ]
[ QUOTE ]
[/ QUOTE ]good plan /forums/images/graemlins/waytogo.gif
There should also be a spot for a threaded fitting on the manifold behind the carb IIRC.
There is a spot, but like you say I'll have to get spacer, because the carb sits too close to get a fitting in the manifold. Do you know of any manufacturers who make a spacer with a port?
TransDapt Performance Products, TRD-2103 on SummitRacing.com for $18.88. They call it a PCV fitting, but it should work.
Speaking of PCV, why not just get a plastic barbed "T" fitting and run the brake booster in with the PCV line.
A carb spacer changes tuning characteristics of the carb, and you may not like the results.
[ QUOTE ]
[/ QUOTE ]Could you pull the carb, install a elbow fitting for the vac line, then reinstall the carb ?? Is there enough room for one of those ??
[ QUOTE ]
[ QUOTE ]
[/ QUOTE ]
I think there might be enough room, but a friend who was working on the truck with me doesn't think so...only one way to find out. Thanks for the replies.
I have one on my 454 bolted to a dual plain spred bore type manifold, so I have an adaptor to fit the holey. The local parts store had the adaptor in stock. I have had no problems with the booster hose but the carb was a wast of money, I'm not sure it betters my 30 year old Q-jet in any way and it certinly is not fuel injection
