mrhoes
you could find a 6 lug SF14 bolt and you could still keep the stock rims, so you dont have to get new rims and tires, that is what I should have done
I know yall are going to hate me for saying this, but I found a deal of a lifetime on my 14ff. I got a brand new from gm, 14ff with 4.56's and a detroit for $550. Just look around, a used 14ff should be more than $200-$175.la_blazer82 said:(a used 14b with 4.56 and Detroit can be had for $400-500). I ended up spending $400 just on a new Detroit.
la_blazer82 said:I'm running 35s, and the money isn't any less, having to re-gear and add a locker.
Not to mention that I ended up loosing more clearance than I thought I would under the huge 14b diff.
dirtwarrior17 said:you can bet i'll be searching for a 14b ff and a cheap d60 at the same time.
You're funny. Good luck though. I ended up paying $1,200 for one that was complete lockout to lockout with 4.56's and a trac-lock.
my local junkyard has em at $500I may need to re-phrase that a little. I personally didnt get it directly from gm, but the place I got it from did. I bought it from a very very large military supply store in west virginia. They get shipments of all kinds of military goodies. They also repair and re-sale military transport vehicles. They have crates stacked upon crates of new from gm military 14ff's (explains the 4.56 gears and detroit from the factory). The also sell complete from hub to hub D60's from GM, but I think they go for $1450 new. They also have crates upon crates of rockwell 2.5 and 5 tons. Hell, the guy up there said he would sell me a used, but in working condition, rockwell 2.5 ton for $450. I just dont have the fab skills to get it into a K5 so I opted for the 14ff which is plenty strong for my application. Anyways, I know that the 14ff's are new because when I got mine home, I opened it up, and it still had the factory yellow marking compound on the ring gear. I bought that about 2 years ago, so I dont know if the price is still $550, or how many they have now. The guy who owned the place must have been too into military parts and not enough in 4x4 parts not to realize that the detroit in the axle alone costs around $400-$450. When I was there, they let me browse at my leisure through both of their huge warehouses. It was amazing all of the stuff they had there. They had enormous pto winches. Must have been like 50,000lb winches. There was also a big box full of (probably about 200 or more) broken rockwell shafts. Those shafts are beefy, and it looked like they were twisted in half like a hotdog.dirtwarrior17 said:when you say you got it from gm what do you mean? Cause if they are selling that combo for 550 bucks i want one.
Anyways, thats how it goes.dirtwarrior17 said:![]()
Lots of folks do it and lots of folks still daily drive/weekend warrior their K5s.
) to handle. Also with the eventual jump to 4.56:1 or 4.88:1 I was worried the pinion would get too small to handle the power/weight. ntaj*ep said:People have their opinions and well you know how the saying goes........Its the people that try to force their opnions down you throat that get to me.
I myself have run an early front Dana 44 and 12 bolt rear with 35" tires for about 10 years. Not alot of breakage, but yes some is going to happen. Its all about how prepared you are (spare parts, tools whatnot) I also have wheeled with some hardcore MoFos from here still running 1/2 ton axles in places like Arizona/Nevada very high traction tight trail kind of terrain. Their upgrades consisted of mostly fuel injection and being totally self sufficant. Lets talk REAL WORLD, will 1 ton stuff be the best damn stuff ever? Will it break and leave you stranded? I for one can tell you first hand I have seen people that can break ANYTHING! Is it stronger that what your running? Sure is but you do not need that kind of beef and the adverse effects they carry at this point, IMO. I think the trend going on here is obscene, you HAVE to have these axles to go over xx" tires or to wheel blah blah. You CAN have fun with what you brung plain and simpleLots of folks do it and lots of folks still daily drive/weekend warrior their K5s.
I'm now in the process of upgrading my rig to complete 3/4 ton axles (after so many years) I will have the same early style 44 front with upgraded axle shafts, among other things (which came over time) and converted to 8 lug. The rear is a Dana 60 out of a Ford with a disk conversion and really thats about it. My reason for this move is only for the benifit of the full floating rear design, and other slightly beefier parts as I plan to go from my 35s to possibly a 38.5 with bead locked rims. I was worried that the jump in shear tire/wheel weight would just be too much (for me and the K5) to handle. Also with the eventual jump to 4.56:1 or 4.88:1 I was worried the pinion would get too small to handle the power/weight.
I will also say this at the expense of others picking me apart. 1 ton parts will not make you a good wheeler. That comes with experance and knowing what your rig can handle. Knowing yours and your trucks limitations at given build up points will make you both stronger. If you build up your truck first with no seat time what so ever, well thats just scary. IMO spend your money on things like bumpers, winch, rollcage, things like that and go out and have fun at your current skill level. You will always have time to be the biggest and baddest, just go get dirty.
