Are these safe?
jamber2541
e.p. texas
Are these safe and has anyone used one before
Steel Leaf Spring Shims
< BACK
2-6 degree, $26.95
8 degree, $30.95
Applications:
These shims are CNC machined from solid steel. They can be ordered in either 2, 4, 6, or 8 degrees. The center pin hole is 5/16 diameter. It can be drilled to fit any center pin size. These shims will not break like most aluminum ones.
most people should have their springs shimmed if there are running a 6"+ lift
Ummm... What? That is way to broad of a generalization. everyone should set up ther suspension based soley on how there rig is setup...:rolleyes:
sorry wrong picture, I meant to post this up, I have shims on my 14b ff
Dana 44 Spacer Block< BACK
Steering
Dana 44 Dana 60 ToyotaSteering Parts
1/2" : $ 15.00
1" : $ 22.00 Applications:
Spacer blocks can be ordered 1/2 ” or 1” tall.
1“ will require longer studs. If using "tall" steering arms, the 1/2" spacers can be used without changing studs.
I like the 1 piece arms better... because the 44 arms use cones... i dont like the idea of a seperate block.
the reason I am asking is I have an arm, I originally went 6 in lift and now I am up to 8 inches of lift. whats the best way to correct this
Either that or get a drop pitman arm. That'll give you another 2 inches and save you a few hundred dollars.
I would stay away from the spacer blocks. Mine had one on it when I bought it and I was getting movement between the arm, block and knuckle, no matter how much I tightened the fasteners.
sweetk30 said:
crossover and dont look back at the old push pull stuff. :wink1:
x a million...crossover is the only way to go:D
Well... if you have a bunch of money lying around, it is.
Us poor folk have to stick to cheaper mods. :dunno:
Crossover setup: $500+
Drop Pitman Arm: $95
Besides that, if it's a DD rig, crossover will give more bump steer.
Wrong, not on all rigs. When I did crossover on my burb, it cured a lot of bump steer.
other than price i cant really think of any reason not to go crossover.
I wouldn't use a spacer block, I have seen them used and the bolts or studs that hold them in tend to break. They seem to break one at a time you go from "my steering feels a bit funny" to " something is wrong" pretty darn quick.
