Jason4x4
LOL, what's your screen name over there? I assume you are Claudia's chase truck? Hopefully I don't need a disguise...
make sure you pack those trailer bearings!Drug the trailer home tonight just to make sure everything was working as it should be. So far, so good. Might load up the blazer tomorrow and pull it home just as a full dress rehersal and see what needs fixin.
Outside of that, just small stuff left. Really could use another week to tune the injection. Got a host of backup parts and can swap back to HEI and carbeuration in Moab if need be.
1 step forward, 2 steps back.![]()
Cheap shocks work as expected, much less bounce on the trail.
Carburetor problem discovered - power piston jammed. No fuel metering at part throttle, header pops galore, a lot more underhood heat all day, resulting in a melted ARB line near the passenger header. Attempts at damage control tomorrow...![]()
you know, if it was fuel injected....Oh, I did as well. There's about 18" where the rubber is melted, and the two lines are inseparable.
Well. ARB line spliced/re-routed. Power piston in the carburetor unglued and cleaned. New fuel filter. Sounds much better on startup. Need to drive a bit to check it out. This better work, otherwise I'll have to rebuild the carb...
Really? Google "stuck injector".![]()
Well, Are you?!?!?!
I almost miss it
