84gmcjimmy
1 ton status
It uses the engine rpm to slow the vehicle down while you are off the gas. Without compression braking, your transmission would act like it was in neutral when you are not on the throttle. Stock slush boxes all have this feature but most manual valve bodies do not. Art Carr is the only one who sells a valve body for the th400 that is set up this way. Other companies can custom build them for $$$$. Hell once I got mine, I figured out how they make them. I just can't manufacture the parts I need to do it /forums/images/graemlins/shocked.gif
okay thanks! I will deinfitly get compression braking when I pick mine up in a year or so /forums/images/graemlins/doah.gif
