elyon
I replaced my whole system a year ago. Every thing. Charged it with 134a to 80% of original R12 charge and it ran fine for most of the summer. Then the compressor seized. Replaced the compressor, condenser, accumulator and orifice tube. Flushed the hoses and evaporator. Added ester oil, charged with 134a. Ran fine for a while then started to heat up. Compressor developed a leak. Replaced the compressor. Flushed the condenser, hoses, evaporator and replaced the orifice tube. Charged with 134a. Ran great for about 30 minutes. Now starting to heat up again. I also installed a trinary switch a while back. Aux cooling fan for condenser. At all times I used a vacuum pump to draw the system down for an hour before charging.
My system uses the pancake style compressor. 1986 Suburban.
I'm lost. Any thoughts???
