Well I havent let the stupid carb issues get in the way of working on other things so I tore into the doors this week. Im trying to get as much done as possible before Im out of my house and dont have anywhere to work on the truck for a while.
40 years worth of dust is residing inside of every panel of this truck.
All of the window seals/wipes/trim were completely dry rotted to the point the rubber wasnt rubber any longer, it was plastic. Literally had to chip a bunch of it out with a hammer and chisel/screwdriver. Wound up with a bunch inside the door before I realized I should put something over the window opening so sh*t wouldnt fall in.
New stuff looks good.
I wound up missing one rubber piece to reset the triangle window glass so I didnt get that done. Hopefully it doesnt come back to bite me since I got it all back together already ha.
I completely cleaned and regreased the tracks and pivots on the regulators and white lithium-ed all the hinges, handles, lock cores, springs and misc. moving parts. Everything works incredibly well!
[video=youtube_share;svcuCKDSbfk]
Reused my crappy door pockets for now because the ones I wanted were out of stock at the time. Same goes for the armrests. Not sure if I want to try finding the matching "buckskin" ones, get black ones or use slightly different saddle colored ones like I have. Everything is brand new except the switches and switch trim.
The drivers door for some reason had an extra 18" of wire twist-tied into the window motor. Not sure why, the factory wiring was long enough to reach so I took out the patched in piece and cleaned up/re-taped all the wiring in both doors and reassembled everything.
Driver side
Passenger side
