Atlas II Transfercase Installed with a couple Pics
DPI
In the Burbs close to Tulsa, OK
Still have some work to do - Lengthen rear shaft, shorten front shaft, grind on HAD front shaft to help with the angle, install shifters, weld up floor board where cut to clearence, ect.
Here's a couple shots of the crossmember I fabbed.
That was the plan. But, I burned up the tranny in the '90 and the other tranny and Atlas were just sitting there....
The Atlas install was a little more complicated than I thought it would be. But it's coming together nicely!
Can't wait to try out the twin sticks!!!
DP - in a year or two when you get tired of that setup, will you sell it to me for what I paid for the 241? j/k!!!! (but that would be sweet)
lol :) Doubt this setup is ever coming out. However, the next project may have a Stak case instead.
I ground on the tranny a little to make it work with the 1350 HAD. I took it for a test drive yesterday. All I can say is 4.3:1 is LOW! And it is nice to have a twin stick.
