ATTN. MT mike Crew cab swap questions
original balzer
roosevelt utah
I did a search but couldnt find it. I KNOW someone on here modified the floor of his crew cab so it would fit a shorter frame. I figure I will build the red diesel pickup then fix/modify the crew cab floor and swap it on at a later date. Thanx
Balzer
(edit)
MTmike, someone pointed to your thread as I requested. Now I have a few questions for you.
1)These areas where you cut the cab to clear the frame seams to be structural part of the cab. I was wondering how well its holding up as im sure you have been wheeling it.
2)Are the circled areas the only place you had to actualy cut to the inside of the cab?
