t should bolt right up. I put a 700r4 in my 71 c20 that had a th350 with little effort but it was a long time agoI have a column shift for a th350, can I make it work on a 700r4? Or will I have to get another column shift?
I'd try that firstMine wasn't shifting to 1st gear. Maybe I need to adjust it
Where is that plate located? How do I get to it? Is it easy to change?You might have to get a new column detent? plate. On the inside of the column is a plate with the shift pattern for your trans. The 700 will require one with another notch.
You might be able to use the 350 plate and play with adjustment, not sure, but to do it correctly you need the plate.
Thank you, I'm gonna work on it this weekend. Been trying to find the detent.It is down below the tilt housing. The 4 torqs screws that everyone tightens to fix the tilt, you will need to remove IIRC. Hmmm I wonder if I have an extra plate.
Mine won’t shift into 1st gear either, only about half way when it stops and I can’t pull down any more. How do you fix it?
