Auto locking hubs not sliding in
jeff l
New Orleans
I changed my rear axle to a 14 bolt 8 lug. My front is still good i don't have the money to rebuild my front doner 3/4 ton axle. So i regeared my rear 14 bolt to 3.73, and changed out the outers from the front 3/4 doner
My problem is I am using the 1/2 ton auto locking hubs on the 3/4 roter/hub.
got one side on and the other side will not slide on far enough to put the ring in.
thanks, Jeff
1986 FS Jimmy (my truck)
1981 14 bolt 9.5 ring SF (Doner)
i say ditch the auto locking hubs and get a nice set of warns or mile markers... the auto hubs are dumb... IMO
LUKE
Sounds like one of two things. Either the axle stub isn't sticking through far enough (in which case, just push it from the back side) or your pinned washer that rides on the inner nut isn't seated in one of the holes.
The second one is the most common reason for not being able to get a locking hub in place.
checked that more then once; ended up being the last 1/4" of the hub was out of round I could see it was a little dented on one part. I ended up useing a Drillmal with a grinding wheel to it; after a little bit of grinding the auto- locking hub fit.
Thanks 1st time doing this and needed all the help I could get,
Jeff
