Auto to man. swap Q's
Geargrinder
Medford Oregon
O.K., I have an '86 Burb, 700R4, NP208. I have an '84 Burb, SM465, 208.
I will be swaping the SM465 into the '86, but the cluch pedal I'm not sure on.
Will the cluch pedal ass. just bolt into the '86? I know that I need to cut a hole in the floor for the rod to pass through. It's the pedal it's self that I don't know about.
Look up under the dash for mounting points. If there isn't any from the factory, you'll have to fab up something.
they should, in my 86 pu i put pedals from a 79 in, they bolted right up, then i put some hydro pedals in and bolted right up
I know you've got the stuff for mech., but if you can get your hands on the hydraulic stuff, it would be an easy (and better) swap. The '86 has all the points/dimples for the hydraulic clutch stuff.
Just an idea if you can find the hydraulic stuff cheap/free. I know in some places it's not tough to come across.
