GalDemSuga
Folks, I have a huge problem and need help. The front driver's wheel hub is rocking causing the rim to grind on the brake assembly. I believe the spindle nut may have come loose. I had the ball joints replaced and the shop may not have torqued everything correctly.
I am attempting to remove the locking hubs and I'm lost after removing the 6 bolts and cap
