Found this on YouTube. Thought it may help to understand the way leaf springs and shackles work together. Great video! Not sure if anyone has shared this yet or not.
Please clarify. In all cases, all load is on the spring.If you run the more angled shackle, more of the load is on the shocks and the springs aren't doing as much of the work.
Probably not really worded the best. I would say the shock has to do more dampening work with the angled shackle.Please clarify. In all cases, all load is on the spring.
I have the 5125 Bilsteins in the (stock rear more slack) position.My blazer felt like I was driving a water bed. I put on the ORD 5125 bilsteins and it feels great. Not too stiff but not a water bed either. Can’t guarantee thier valved bilstein shocks will fix your ride but they did for me.
My shocks on the front and rear are installed in the stock positions with a 4” lift. 9.24 travel in front with 11travel in the rear.
These trucks I doubt will ever ride like a Cadillac
It would really help if the shackle was in the picture.
Needing some help with my rear shackle set-up on the Xterra. It's sprung under and I'm not sure of the math to check my shackle angle and order new springs eventually.
My Alcan leafs are bending in front of the axle. I believe this is because of axle wrap. But I'm approaching their weight limit.
I'm going to need stronger springs but I'm wanting to keep the longer rear shackle for better articulation. But I need to better understand shackle angle in this instance so I know the lift/capacity specs I need to
order.
