axel change?
ddg551
New Jersey
If I put in a 14 bolt, will i have to put in new front axel or just regear. My friend said i need a new front axel.
no you can change your current front axle to 8 lugs via the conversion featured on the home page of this site.
or if you already have 8 lugs like the 14 bolt you may need to regear to match them.
or if you have the six lug 14 semi floater you may have to regear them.
technically all u have to do it re-gear the front axle, but being a 1/2 ton(6lug) im guessing it is...its not really worth it, plus people might look at u funny with 8 big lugs in the rear and 6 small ones in the front, i would find an 8 lug axle for the front and use that, re-gear it if u have to....or do what i did...i put in my 14bolt and didnt have 4 wheel drive for a while, until i found a good 8 lug front axle and put it in.....OR.....find a complete truck that someone has if it has a 14 bolt, use both axles out of that, u can find a beat up k20 pretty cheap....good luck!
