Dafey
Where can I get steel axel shims cheap? I need 6* shims quick.
Nope nothing like that here . Roswells pretty small like 50k people and a lot of thats farms.
There a little higher on most of there stuff..here is another option, never ordered thru them and not sure of price if its good or not, but here ya go http://jkwoffroad.com/offroadproducts.php
What size are the center bolts on the feaf springs 5/16-3/8 or 7/16 and how long from 3 to 5" ?There a little higher on most of there stuff..
I found some for $30 w/bolts..can anyone top that? Lets have a contest.![]()
If you're running a zero rate up front and are gonna sandwich the shim in between the leaf pack and zero rate, make sure to use grade 8 bolt thru the leaf pack or this might be problem like it was for me
http://coloradok5.com/forums/showthread.php?t=234154&page=4
Damn I already bought some shims.... From now on Im just going to ask you if I need something , before even thinking about buying it..You always seem to have what ever I need !Don, I have a pair of aluminum shims you can have, and center bolts(3/8) are available at Roswell Livestock Supply.
