Axel shims
Nope nothing like that here . Roswells pretty small like 50k people and a lot of thats farms.
There to hard to count,always coming and going .plus you never know how many are hiding out.
I found some for $30 w/bolts..can anyone top that? Lets have a contest. ;)
I think I actually have a used set at the house that came with the 52's. Ill check on the degree of them. If you want them Ill let you have them. just pay for the shipping.
Just make sure they are steel. I had a shop list them as steel once on there web site. When I got them they were aluminum. Sent those ****ers back.
If you're running a zero rate up front and are gonna sandwich the shim in between the leaf pack and zero rate, make sure to use grade 8 bolt thru the leaf pack or this might be problem like it was for me
http://coloradok5.com/forums/showthread.php?t=234154&page=4
No , its going in or I should say ON the rear. After the 4" lift I had to get a longer Drive shaft [D/S]...THEN when I hit
the brakes HARD the D/S at the axel trys to bind up. The part where the u-joints are , try to bind up.
So I need to angle it up some to keep them apart.
I couldnt figure out what the DARN poping noise was when I hit the brakes....Thought I had a loose
bolt or something..:rolleyes:
Then one day I was under there fixing a broken wire and got to stareing at the D/S waiting
for the wife to bring me a lighter for the heat shrink
and - POW , simple once I looked at it. :doah:
Don, I have a pair of aluminum shims you can have, and center bolts(3/8) are available at Roswell Livestock Supply.
Damn I already bought some shims.... From now on Im just going to ask you if I need something , before even thinking about buying it..You always seem to have what ever I need ! :haha:
What size are yours in case these 6* dont work?
Maybe Ill stack all them suckers up together and make it point
right on up there... :doah:
Ill keep you in mind Jimbo , Thanks.
