Axle id help
kbclamper
ca
This dana 60 came with a front d60 that i bought. It has drums and is full float. Tag says 410s is the plug for and elocker? Any idea what it came out of? Im assuming this would be better than my than my locked semi float 14b
Dana's have a number stamped in the top of the pass side tube BOM. Dana uses these numbers for part look up. Should be a published list of those numbers with specs
4.10 w/ limited slip. kinda looks like a ford tag, is hard to read. get out a wire brush
The front is a king pin dodge. The rear is not from the same truck i was told. He didnt know what it came from.
Havent tried yet. My spare is currently on the roof of the suburban. I checked the passenger tube and dont see anything stamped20230315_151513.jpg
Holy crap are those drums big.
Ford normally would disc on d60 with abs sensor. If that is what the pig tail really is.
Looks bigger than a 60 from here
Check the rear face of the passenger side axle tube for a BOM, probably around where you see the brake tube has that little hump between the retainers.
Have you looked at the lower right rear diff webbing for 60 or 70? I agree, that looks big for a 60.
Looks like a dodge 70 rear to me…..I’ll take a pic of mine tomorrow to compare…60 and 70 share the same cover but the housing is slightly Beefier. Agree that the pigtail is likely for a tone wheel
Got a good picture of tbe tag finally. Whats it mean or how do i decode it20230316_174654.jpg
605509 CHRY 70 REAR 1991-93 1/2 D-200 & D-300 & D-600 & D-700 W/ABS
