Axle ident. help needed!
Found this on the currie enterprises website.. looks like a match to me.. what you have is definitley not from an F- body.
The Currie Stage II GM A & G body Rearend
Chevelle - Malibu - El Camino - Monte Carlo - Cutlass
Gran Sport - Le Mans - GTO - Grand Prix
Isn't that just a 9" setup for a G-body?
I don't see any diff cover bolts.
Any even halfway modern rear drive coil spring GM car is going to have those upper control arm "ears", that narrows it down to what, 1964-2002 cars? Not very precise.
Yeah thats just a 9" which is not under this Camaro
I don't see anything other than a dana 20 that it could be.
That rear cover, along with that "truss" running under the center section, will give that axle away to someone who knows what it is. The upper control arm ears are pretty much pointless, that is a generic feature for most coil sprung rear axle cars, regardless of make.
Sorry, Just saw the picture and keyed on the ears and diff cover.. didn't read the description.. I'm guessing, just like everyone else.
Wonder if there are any ID numbers left on the axle tubes..
Yeah I think its the AMC 20... looks like the one under my buddies CJ5
Yeah, that's the closest I can get but Dyeager says, the ears and truss would identify it to someone. I've spent hours searching but still can't find a match. I don't think the m20 has that truss thing either, but I've not had the opportunity to get under one and look for myself.
onlychevy6 said:
how long have you had the car? It kinda looks like a newer GM rear end. However I forget what the old dana's looked like that the cuda's and others ran during that time frame.
Old Mopar Danas centersections look just like what is in the front of most CK5 members rides , only rear semi floater with 5 lug axles :D
As for the Camaro rearend , it looks like an old A-body 10 bolt , NON Chevy style . They had 12 bolt covers , the trailing arm ears like any other A-body , and 10 bolt ring gears :D
I was the Chevelle guy before I died and was ressurected as a Blazer owner :wink1:
I've only seen these with 10 cover bolts. Got any links or photos?
Why can't people just use mainsteam stuff?!!!!:rolleyes:
Whats above the pinion snout? The other pictures online I could find of a 20 showed a pair of lumps over the pinion snout cast into the housing. In your picture it looks like something there, but can't tell clearly.
Couldn't find a single picture of a 20 online from the angle you shot, showing whether they have a "truss" like yours.
There's 3 equally spaced square 'lumps' around the snout.
Lemme see if I can find the 20 pictures I was looking at last night.
These were more tear-dropped shape as I recall.
Well looking at some pics , the cover is too round to be a 67 Olds 8.5 axle ( http://www.oldsmobility.com/10bolt-tech.htm ) . I still kinda think it may be .
The ears looked cast on due to the paint , are they welded on and ground smooth ?
I remember some sturdy axles from the 50's had round covers . I think this search is kind of fun :thumb:
Well...it's got the 3 lugs on the snout like a 20. It's got a single side rib like a B, and it's got cast on ears and a round cover like the O ! But none of these have the 'truss'. The 20 is the closet.
Here's a view with the cover off. No part numbers on the r&p. Anyone recognise the posi/lsd unit? No brand castings/markings either....someone dis-owned this axle!!!
Looks like someone did some weird voodoo there . I see 3 ring gear bolts , now mirrior that and add one top and one bottom , you have 8 .
Looks like a model 20 the more ya look at it internally .
Yeah, kinda spooky and really frustrating!!
Someone send me a 12blt!!!!
12 bolts are really scarce , I would actually run a 10 bolt with a quiet locker and good axles ( my plan on my Chevelle ) .
Or order a 12 bolt from mailorder parts , it would be a reproduction , but stronger .
