jms said:Here we go again...![]()
Just tell the guy to get welded 1-ton axles, 44's, and heck, while he's at it, why not turn it into a tube buggy now...
I did suggest that he buy lunchbox lockers and run it.
I am one of those guys that bought a detroit for the 12 bolt that was under mine stock. At that point I was one of those that said 35's would be the biggest I would ever go. I regretted buying the detroit about 4 months after getting it because I could have had a FF 14 bolt with a detroit and pretty much whatever gears I wanted for less than the detroit. I ended up shearing off one of the bearing journals on that detroit (on the street!) and got all my money back. I was lucky and that is when I switched to 1 tons. At the very least, I would swap to a FF 14 bolt and get a detroit for that. You will probably end up at the same cost and will be way stronger. I wouldn't throw $1000 at a dana 44 for an ARB because that is alot of money to risk with something you may change your mind about later. Just relating to my own experience.
