Axle Width
jdbuckshot
Mississippi
88' GMC Jimmy
my rear axle seems to be a few inches narrower than my front axle, is this normal from the factory or has it been swapped?
rear axle - outside of tire - out ide of tire 75"
Front axle - outside of tire - outside of tire 80"
Thanks
Its normal, helps with turning radius and a couple other things, if you want the same width, use spacers swap in a van axle or a newer axle from an IFS Chevy they are pretty close to the same width
Thanks,
Im all stock right now. just wondering how guys with lifts, tire/rims get that look.
How wide is the factory k5 rear? How much wider is the van or IFS rear?
