KGsK5
wow thats awesome. im extremely jealous of you AZ guys.
colbystephens said:http://www.coloradok5.com/forums/showthread.php?t=193774probably won't go quite so high, b/c i'm cutting out rust on the doors and the door sill... but...
i'm going as high as shawn did on his cut. maybe it will give you some ideas - but probably not b/c your rig is so much prettier than mine.
Then I need to clean up the springs I have and install the lift.
the pics of allan going down the luge are good for perspective on the tight fit and high walls.colbystephens said:dustin - i dig your pics. i'm going to have to snag a few of those.the pics of allan going down the luge are good for perspective on the tight fit and high walls.
greg - it's 2x6. any wider would have required more cutting, or more than i want to stick out would stick out. i could go for one more inch sticking out and having it taper near the wheel wells so that there's no edges to catch on stuff.
colbystephens said:my step is now 3.5 inches higher - the wifey is demanding a stirrup to help get in.![]()
