Square body 52in front swap kit complete for dana 60 and 10 bolt ( different u bolts). This gives you 4in or 5in lift or more really not sure that's what they say
Pulld these parts off because I am installing a coilover kit on my blazer
If you want to run this with a 10bolt front you just need to use the stock spring plates and possibly longer u bolts.
Parts listed
Diy4x B-52 front spring mounts
Diy4x 6in shackles
ORD 6 degree shims
Dana 60 u bolts and spring plates
52in leaf springs ( stock rear leafs)
Doetsch tech 14in travel shocks ( they work as is just old would reccomend needs rebuilt threw the shock company )
Home made shock towers with bump stops (you need to use your bump stops)
Located denver can transport to Blazer Bash
$300
Parts listed
Diy4x 6in shackles
ORD 6 degree shims
$300
