B&M 700R4 deep trans pan question.
id get the filter extention that goes with that (70288), and it should be fine. Get the cast aluminum if you can. Chrome sucks
Aluminum = Much better cooling. Hot tranny fluid...bad. Cool tranny fluid...good.
What's the problem with chrome? Aluminum is 3 1/2 times the cost of chrome ($175. VS. $50.)
In my experience, chrome covers -- tranny pans, valve covers, diff covers, etc -- don't fit. Either the chrome-plating process warps them or they're just poorly made ... but I won't use 'em. Gimme normal steel, aluminum, anything else.
-- A
deep trans pans do not fit on blazers/Jimmy
stay away from chrome it leaks like crazy!
Exactly. Chrome doesnt dissipate heat. I picked up a deep aluminum pan on ebay for $50 or 60. It fit fine, had to drop the driveshaft though to get it in. It was polished, but a trip through the mudhole and it looks better.:D
