B]What Carb to Use [/B]
fire dawg
new mexico
I have a pretty stock 400. i have an RV cam with an edelbrock performer intake. I have an edelbrock performer 750 lying aroud. is that to much carb? If it will work, what size jets should I run? If it is too big, what do you guys recomend?
I recommend my Rochester carbs that I'm selling..... :D Decent bowls make it not bad off road. :wink1:
I had a performer 750 on a fairly built 350 and off idle sucked-even after messing with jets, metering rods, and springs. Called edelbrock and they basically said that was normal. Only recommended for well built 400+c.i.d or stock big blocks.
