Yeah I had to cut all that off the frame. Came out good I think. I didn’t even think about the torsion springs. You are right it could be done but wouldn’t tuck.I don’t think you could have done that with a blazer gate. The hinges would be right in your way plus the torsion springs would be too.
Excellent work. High and tight!
$400 for that isn’t a bad price considering the time it would take for me to build it.Blazer Bash 2023 last minute thrash.
Because no one else has started this thread, where are you at in your prep? https://www.timeanddate.com/countdown/generic?iso=20230908T08&p0=4781&ud=2&font=cursive&csz=1ck5.com
I was looking at this one as well. Do you have any install pics?![]()
GM Winch Cradle
GM Winch Cradle that supports most 10,000lb winches with a separated solenoid box. The solenoid box will not fit above the winch, and must be located either off to the side of the winch or moved up into the engine bay or wherever you see fit.cfm.industries
I've ran this one for years, i just added a bit of pipe work for the sides.
I just cut mine. Looks better your way but I have no patience or timeDecided the fangs need to go up 3”
View attachment 462457View attachment 462456View attachment 462458View attachment 462459
Didn’t take that long really few hours. Really best time to do it is before paintI just cut mine. Looks better your way but I have no patience or time
