Back In the Saddle Again
Would really like 3.73 so if I end up putting a 4 speed in it won’t be a dog
Mine has the 465 trans, and 3.73 gears. works fantastic with 33-35 inch tires. Have done both tire sizes, and was best with the warmed over engine that i built, and 35inch tires. I towed everything on my flat bed like that too. occasionally might use low gear in traffic or starting out on a hill...
Had to drop a used stock tbi engine back in recently, and there is a LITTLE difference off the line, but is not a problem. entirely useable on the street. final gearing on this is similar to what the truck came with stock? -30 inch tires and 3.08 gears.
no plans to change anything anytime soon. might not be the best set up with an anemic engine, but i dont see any lack of power off the line from a stop. RPMs @ 70mph are reasonable. Changing to nv4500 with 4.10 or 4:56 might be fun, but makes no sense for me for fuel economy, or for the end result/usability. would be nice to be able to shift a little more quickly, but im happy with what i got for now, and thats part of the reason my build thread says something about "the compromise"
-i should add that the low range gearing in the NP241, and having the manual trans helps make this tire/gear combo work. stock gearing in the 205 is only about 2:1?? even with the granny gear in the 465, that might leave something to be desired with a 2:1 transfer case. And torque converters on the autos rob horse power at all time they aren't locked, correct?
I’m running 4.56 with 40’s. No overdrive. I keep my tach between 2750-3000 when I’m on the highway. Whenever I check my gps, I’m running between 70-75mph.
I have the same combo as fasterEddie and a little less motor ; wheels fine all day and as he says 70-75 on the freeway and not struggling to do it and more go Pedal there if I want it.
Yes, larger tire size wil drop the RPM on the SM465. 40” would be much better with 4:88 than the 37” I had. When I ran the 35” the rpms were crazy high with that ratio.
Haha man, the glued down sound deadener just peels right up off the floor on these desert vehicles. Wow, this is fantastic. This is my first time working on a truly desert southwest vehicle. No rust, no moisture and everything comes apart as it should. I’m fascinated by this.
For the rear side panels I want to build them out of ply wood and wrap them in vinyl. However, I want to also add storage compartments throughout. They make some cool marine style hatches but I’d like to find a metal hatch that locks.
Yeah, the guy I sold the Jimmy to loved it. I wish I could have brought it with me but I told you I would be back :D
I stuffed the shovel in the uhaul and then drove down. Just sold it a week or so ago. And with the money I gained on that I was able to pick this K5 up and my wife a decent car. Actually the same exact car she had before that she totaled.
Yeah we haven't got together yet, @K5Devil works to much to hard, I've been a little busy, now the holidays are here. I do have some stuff K5devil might be interested in. esp when he goes 8 lug.
It'll happen.
