Backspacing, U-joints, questions....
ezoliver
Mall Crawler
Elizabeth, Crawlorado
Want to order my beadlocks ASAP... Getting Walker Evans :D
Do you guys have a recommended backspacing? :confused:
I am running a D60 up front and 14 bolt out back will be putting 39.5x13.5x17's on.
Also want to order my Atlas II ASAP... :D
Think I have settled on running 1350 joints, but should I run CV shafts front and rear and go with a flange setup on the t-case? Or do you guys recommend something else? I have about 6" of lift over stock height.
THANKS!
all i can say is have you read your eye's out till thay are ready to fall out ?
few big buys planed i see . make sure its what you want.
and before you order search a few big boards like us and pirate4x4 and others for deals from vendors and other members for private sale. i have found some smokin deals for around 1/2 price. so saving money is always good. http://www.craiglook.com/index.html
some of my stuff was kind of impulse buys and wished i had read more and asked questions. hopethis helps a lot. and good luck we want build pics.
drive line stuff look here for options and prices. http://www.highangledriveline.com/
I have 3.25" bs on my Allieds. Seems to work well. I know Adventurous4x4 on here runs the Walker Evans beadlocks. In the 17" variety I am pretty sure you are good with up to 5" bs. All depends on overall stance you are looking for.
I run a 1350 CV rear shaft and it works well. 1350 isn't great for a bunch of angle at the pinion up front. If you are droppin some big $$ for shafts go 1410.
I ran 2.75" w/15x8's and I think I'm running 3.25" now with 15x10's both on 42" IROKs.
I love it, wouldn't change it, but it's wider than most go with.
I wanted to keep stuff tucked in a bit more...
I ordered up the beadlocks with a 4" backspace.
Ordered my Atlas II with 5:1 low and flanges for 1350 CV's front and rear. (with the disk e-brake on rear output!) :D
Bought my 39.5 IROK radial tires and will be picking them up Wednesday.
