MODS: Please move to "Injection Section" if necessary
Bad Injector: Yep
Coming home from the parts store, and while I was on a straight a way, I decided to punch it after it shifted to second to see if it would down shift like it should. And it did. By the time it had shifted to 3rd I had to slow down to make a turn and the blazer died. I shifted to neutral and tried to start it but no go. It would crank over but wouldn't start. I pulled over and started all my checks. First thing was to check the fuses. Both good. Then turn key to on, hear the fuel pump prime, and smell lots of gas.
The wife came to give me some help just in case I couldn't get it started. I had her turn key on but not start it so I could see the spray pattern. Well, there was a spray pattern but it was on the passenger side injector only and it was dumping a lot of fuel when you turn the key. The other injector just sat there. Nothing. I switched connections and same thing so I figured it must be a bad injector. Thankfully I carry a spare set of injectors and went ahead and replaced both of them. After a couple of cranks it finally started. Took her home and checked everything out and all seems ok.
So I'm guessing it was a bad injector. Eventually I'll have to swap the suspected bad injector to make sure but right now I'm nuts deep on a pontiac 400 tear down and need to get as far on that as possible.
Now, there have been a couple of times when driving the blazer it would just die. Wait for a minute and it would start right up. That hasn't happened in a couple of years but it still makes you wonder what caused it to die.
Bad Injector: Yep
