Sorry for the confusion. I just went in and removed the extra period. Let me know if that helps. Datalog is only 19 KB
Do you have to manually enter all info from Tunerpro to Excel or is there a way to enter everything at once?
I think I know what you mean. In TunerPro, go into "acquisition", "export log file". It will give you the option for .csv, and you can select all the data you want to see from that list from that window. The attached file is what I ended up with from yours, once I deleted everything I don't think will help. Just remove the ".txt" of course. Note that you can edit the actual datastream, so it doesn't list all the junk that is worthless in your log. Under "acquisition" again, then click on "edit definition". Within the editor it looks like it's "item list views" then "default view". I *think* if you remove certain items there they won't be logged. I haven't played with that for a long time. I notice that not everything that is in the datalog is listed there either. While it's somewhat annoying having a ton of blank columns, it's good to have the error codes still there, I've had issues with bins that have been corrupted, that don't trigger the CEL, but show in the log as flagged, which may change what the ECM is doing.
Did you figure out how to replay the datalog in Tunerpro as the graphed values? I know EagleMark really liked that function, I personally prefer the spreadsheet, but whatever works for you. I was seeing some lean AND rich areas, what I prefer to do is find someplace you can maintain a specific speed/load on the engine (flat ground initially) to get your BLM's roughed into ~128 under those conditions. As in, start at 25MPH, log, evaluate, change fueling as necessary, retest, once good move up to 35MPH, etc.
I always look for knock counts. If you see knock, and see a lean condition (higher BLM) then you want to look at few rows prior and see where fuel starts to go lean, then fix it. The problem isn't when the knock count registers, it's the brief period leading up to the knock that is the issue. I'm pretty ignorant on the TBI setups, on TPI I'd be looking at AE if it was going lean as I rolled into the throttle. I'd also look at timing, but I don't see it in that datalog.
It's all a dance, I look at TPS, vehicle speed, load, and RPM to determine what the input is from the driver, what the load is, then look at the BLM's and O2 sensor to see what they are telling me before I start messing with fuel and timing. The narrowband O2 is a bit of a hindrance, but as slow as the transfer rate is on this TBI (160 vs 8192 baud on most everything else OBD1 GM) much can change between two cells that you can't see anyway.
I could be wrong, but I *thought* someone had made a tool that would rough in your VE table for MAP. Could be wrong, but I thought there was.
FWIW I attached a random extract from an old TPI datalog to show you what the faster data transfer gets you. You can see there is a lot more resolution. One reason the later TBI ECM's are preferred if you are going to be doing a bunch of tuning.
