So I bought this truck and have minimal driving experience with it. I’m restoring it now. I noticed it would smoke on start up and while running; so I attributed it to bad valve seals (easy fix) or carb pouring fuel. I have done warm compression reading tests and they were beautiful across the board.
So I bought some valve seals and a cylinder pressurizer tool. The tool has a valve that I can shut off pressure( I have a small pancake compressor). The cylinder I can hear and see bleed through the intake. The pushrod for the exhaust Cyl 2 had copper on the lifter side. Is this bad guides?
The truck has a crate short 350 and I guess transferred the original 305 heads (801) and intake over.
What are your thoughts?
. The shadetree way is to simply push on all of the valves with springs still attached and see if you can move them at all N, S, E, W.
