My new truck needs upper and lower ball joints replacement. I'm not a mechanic. I just got a quote from one shop of $750. It seems a little high. What do you think?
Ball joints are not hard, just plan on it taking a whole weekend for a first timer.
and i had to call my friend i got the truck from cause i forgot how the bearings go back in. 1 3/16 socket 15.00
Spindle nut socket 15.00
Spanner socket for adjusting sleve 20.00
The 1 3/16" socket is for the nuts on the ball joints.
Spindle nut socket should be a 4 prong.
The spanner socket is for the adjusting sleeve that the upper ball joint goes into.
You should be able to find the tools at a Napa, Autozone, Advance Auto. I've never seen a spindle nut socket at HF, same thing with the spanner socket.
Are all the 4 prong spindle nut sockets the same size? I think i recognize the spanner socket now, i will check kragen. I think i've always just used a box wrench on the ball joint nut, but i will get the appropriate socket.
Thanks for your help. You know how much easier this stuff is wiht the right tools!
