DEMON44
Low-Tech Redneck
what a full banks kit worth? I really don't know. I might be able to get a whole kit (on a 6.2 that smokes pretty bad) all together for around $500 cad. is that fair price?
that includes a complete 6.2 engine too......so it sounds worth while then.
But I'm that stoked.
Nice buy man. If you weren't a quarter the world away i Have a C code intake and a set of oversided pistons from a gm crate 6.2 with less than a thousand miles on them. Just be carefull with your boost pressure. (the whole reason i have the pistons and intake) Friend of mine tried to push 20 lbs of boost. Crank didn't take it for long. Bout 1000 miles. 21.5:1 compression + 20 LBS Boost = Snappy
70psi @ 17:1CR my 24v spit out the head gasket
and I drove it home.
91 also has the thick block that has enough material to be bored out to a 6.5L safely. See if you can't get that 205 off him too![]()
