Barnes 4wd
http://www.barnes4wd.com/product_info.php?cPath=470_126&products_id=2438
[FONT=arial,helvetica,sans-serif]This is the kit that has all the parts that we are always using in the shop for customers Three links suspensions. This has all the parts that are made to stand up to the abuse that Rock Crawlers and Trail Rigs see and then some. The kit includes. [/FONT]
[FONT=arial,helvetica,sans-serif]1 x [/FONT][FONT=arial,helvetica,sans-serif]Axle Link Mount Pair[/FONT][FONT=arial,helvetica,sans-serif] 10 Deg[/FONT]
[FONT=arial,helvetica,sans-serif]1 x [/FONT][FONT=arial,helvetica,sans-serif]Frame Link Mount[/FONT]
[FONT=arial,helvetica,sans-serif]1 x [/FONT][FONT=arial,helvetica,sans-serif]Adjustable Inner Frame Link Mount Pair[/FONT][FONT=arial,helvetica,sans-serif] 0 Deg[/FONT]
[FONT=arial,helvetica,sans-serif]1 x [/FONT][FONT=arial,helvetica,sans-serif]Link Tower[/FONT]
[FONT=arial,helvetica,sans-serif]1 x [/FONT][FONT=arial,helvetica,sans-serif]Outside Frame Panhard / Trackbar Mounting Bracket[/FONT]
[FONT=arial,helvetica,sans-serif]1 x [/FONT][FONT=arial,helvetica,sans-serif]Offset Axle Panhard Bracket[/FONT]
[FONT=arial,helvetica,sans-serif]1 x [/FONT][FONT=arial,helvetica,sans-serif]Chromoly 3/4 - 16 X 3/4" Heim[/FONT][FONT=arial,helvetica,sans-serif] RH[/FONT]
[FONT=arial,helvetica,sans-serif]1 x [/FONT][FONT=arial,helvetica,sans-serif]Chromoly 3/4 - 16 X 3/4" Heim[/FONT][FONT=arial,helvetica,sans-serif] LH[/FONT]
[FONT=arial,helvetica,sans-serif]2 x [/FONT][FONT=arial,helvetica,sans-serif]High Misalignment Spacer - 3/4" to 5/8" Stainless Steel (pair)[/FONT]
[FONT=arial,helvetica,sans-serif]1 x [/FONT][FONT=arial,helvetica,sans-serif]3/4" - 16 Jam Nut[/FONT][FONT=arial,helvetica,sans-serif] RH[/FONT]
[FONT=arial,helvetica,sans-serif]1 x [/FONT][FONT=arial,helvetica,sans-serif]3/4" - 16 Jam Nut[/FONT][FONT=arial,helvetica,sans-serif] LH[/FONT]
[FONT=arial,helvetica,sans-serif]1 x [/FONT][FONT=arial,helvetica,sans-serif]Tube Insert (3/4-16) 1" ID 1 1/4" OD Tube[/FONT][FONT=arial,helvetica,sans-serif] RH[/FONT]
[FONT=arial,helvetica,sans-serif]1 x [/FONT][FONT=arial,helvetica,sans-serif]Tube Insert (3/4-16) 1" ID 1 1/4" OD Tube[/FONT][FONT=arial,helvetica,sans-serif] LH[/FONT]
[FONT=arial,helvetica,sans-serif]3 x [/FONT][FONT=arial,helvetica,sans-serif]Chromoly 1 1/4"- 12 X 1" Heim[/FONT][FONT=arial,helvetica,sans-serif] RH[/FONT]
[FONT=arial,helvetica,sans-serif]3 x [/FONT][FONT=arial,helvetica,sans-serif]Chromoly 1 1/4"- 12 X 1" Heim[/FONT][FONT=arial,helvetica,sans-serif] LH[/FONT]
[FONT=arial,helvetica,sans-serif]6 x [/FONT][FONT=arial,helvetica,sans-serif]High Misalignment Spacer - 1" to 5/8" Stainless Steel (pair)[/FONT]
[FONT=arial,helvetica,sans-serif]3 x [/FONT][FONT=arial,helvetica,sans-serif]1-1/4" - 12 Jam Nut[/FONT][FONT=arial,helvetica,sans-serif] RH[/FONT]
[FONT=arial,helvetica,sans-serif]3 x [/FONT][FONT=arial,helvetica,sans-serif]1-1/4" - 12 Jam Nut[/FONT][FONT=arial,helvetica,sans-serif] LH[/FONT]
[FONT=arial,helvetica,sans-serif]2 x [/FONT][FONT=arial,helvetica,sans-serif]Tube Insert (1-1/4-12) 1 1/2" ID 2" OD Tube[/FONT][FONT=arial,helvetica,sans-serif] RH[/FONT]
[FONT=arial,helvetica,sans-serif]2 x [/FONT][FONT=arial,helvetica,sans-serif]Tube Insert (1-1/4-12) 1 1/2" ID 2" OD Tube[/FONT][FONT=arial,helvetica,sans-serif] LH[/FONT]
[FONT=arial,helvetica,sans-serif]1 x [/FONT][FONT=arial,helvetica,sans-serif]Tube Insert (1-1/4-12) 1 1/2" ID 1.75" OD Tube[/FONT][FONT=arial,helvetica,sans-serif] RH[/FONT]
[FONT=arial,helvetica,sans-serif]1 x [/FONT][FONT=arial,helvetica,sans-serif]Tube Insert (1-1/4-12) 1 1/2" ID 1.75" OD Tube[/FONT][FONT=arial,helvetica,sans-serif] LH[/FONT]
[FONT=arial,helvetica,sans-serif]This is great for the do it your self fabricators looking do their own 3 link system, and did we mention that the kit is 5% off of our regular great prices for the items individually! [/FONT]
http://www.barnes4wd.com/product_info.php?cPath=470_126&products_id=2368
[FONT=arial,helvetica,sans-serif]1 x [/FONT][FONT=arial,helvetica,sans-serif]Link Tower[/FONT][FONT=arial,helvetica,sans-serif]1 x [/FONT][FONT=arial,helvetica,sans-serif]Offset Axle Panhard Bracket[/FONT]
[FONT=arial,helvetica,sans-serif]3 x [/FONT][FONT=arial,helvetica,sans-serif]Currie Enterprises 2-1/2" Forged Johnny Joint - 1-1/4"-12[/FONT][FONT=arial,helvetica,sans-serif] RH[/FONT]
[FONT=arial,helvetica,sans-serif]3 x [/FONT][FONT=arial,helvetica,sans-serif]Currie Enterprises 2-1/2" Forged Johnny Joint - 1-1/4"-12[/FONT][FONT=arial,helvetica,sans-serif] LH[/FONT]
