just a note...i noticed copasetic mentioned he had 2 gauge on B-(negative) and 1/0 on his B+(positive), iirc, the B- is supossed to be the bigger cable, or at least thats what i remember from basic electronics, b4 moving on to B school(miniture component repair) as a radar tech in USMC...if the ground is smaller, no matter how big the positive, it can't flow any more than the ground will allow.
Yeah, I was gonna say "both should be big" ... but it gets complicated quickly and I was trying to give a simple answer
In a regular circuit -- like the power supplies to your radar units -- the positive and negative sides carry the same flow.
In vehicles, though, the ground half is often a different path. The alternator feeds the battery from the alt post to the battery positive (I'm doing hole flow here, people, not electron flow, so don't whine) ... but then from the negative side we go to the frame, through the frame, to the engine block, and then to the alternator. Some of these latter are carrying other loads as well, i.e. the return side of the battery-to-headlights loads, for instance, so they're seeing more load than the charge wire.
Strictly speaking you prolly want BIGGER grounds in this case 'cuz there are fewer of them and they have to carry the most load ... but in a stock system you just need a good path for the starter as it's the only really high current load.
However, my original answer stands: IMO, for stock/ish electrical systems, reasonably short lengths of clean, new, well-connected 6AWG should do just fine.
And yeah, modified systems are entirely different; I've got everything from #10 to #4 on my trucks, depending on distance and load. (#10 for the headlight relays, length of less than a foot, #8 for the alternator charge wire, maybe two or three feet, and #4 for the winch, battery connector on the truck that has them paralleled, etc.)
-- A
