ok, I'm a tad confused as to what you have here, and what you want to end up with....
Im looking to see how to disconnect the rear batteries and still keep them charging
let me see if I have this straight...
You have the 2 8D's in the bed, in parallel, with a single feed up to the isolator, tied into the single front bat, right?
2 front bats in parallel too
and your winch feed also coming off that 8D pos post?
yes the 2 bed batteries only feed the winch (currently)
first off, there's NO excuse for potenential chafing.. go back and do it right with grommets.... do they make 3/0 grommets? I was going to use pvc as you see in the pic.. but they are right over the gas tank and couldnt get the wire to bend that way.... so just cut a hole in the bed.
yes I do want to go back and do it right... I dont feel grommets are good enough as these cables are HUGE
as for seperating or "shutting off" the back bats or winch... theres lots of ways to do this.. you could just run a high amp bat switch on your winch line, or inline up to the isolator, with the dedicated charge with going back to the pos on the 8D...
You could also tie a marine switch into this system.. but I'm still not 100% what your trying to achieve here... well, actually, the easiest thing to do here would be to put a post bat shutdown, something like this,
will that switch handle 500ish amp draw? dont want to use it as in inline fuse...
then run a dedicated charge wire to the positive post on the OTHER battery of the 2 8 D's in parallel... taking those 2 batteries out of the system, yet charging them... you will be beating up the batteries and shortening there life tho... Ideally, you'd be running a load sensing relay like an ACR or similar system..... a marine switch and ACR are pretty much the simplest, bulletproof system...
