hey all, the PO Had a battery blow up on him. He said He cleaned up some, however there is alot of surface rust and some acid corrosion on the frame, wheel well and the body. My question is what is the best way to clean it up? I already made a baking soda/water mix and spread that around hopefully neutralize any acid that is left over.
I was thinking of taking the wire wheel to most of it, then hitting it with some rustoleum. But there are some tight spots I wont be able to get to.
Thanks for any info
Thanks for any info
