Battery operated tire inflater
The outlet of the arb is hot enough to de-crimp factory made air hoses. I had to switch the feed hose from the compressor to my tank from a 4ft rubber leader whip style hose like you would have on a tool to an actual stainless steel braided line. Lost two hoses that way, one of which happened as we were trying to reseat the bead on my tire on steel bender at BB. Should have learned after the first hose failure. Nope.
My only saving grace was I put a quick disconnect for the hose connection at the compressor so in the event of my feed hose failing I just could hook up my air hose directly to the compressor without having to change a fitting.
I've been browsing for a battery operated tire inflation device. Does anyone have they recommend?
I saw this one
I have ridgid tools so I got the ridgid pump, it works off batteries and has a cable to plug in the car battery.
I got one for each vehicle when they went on sale for $49.
Now they are $89
Mine was not nearly as fast to filling up 35’s in comparison to a ARB twin setup like I have now. The ARB is a 100% duty cycle unit.
How do you have your ARB twin mounted in your blazer?
EDIT to add: Nevermind, I searched ARB twin and read this thread before seeing your build thread pop up and seen how you did it.
Glad you found it. I will say it was pretty slick how a generic aux battery tray fit the twin perfectly.
Yeah, I think it looks great there.
Have you had any issues with heat and the compressor being under the hood? Running the M1009 Blazer, I don't have any side panels on the bedsides. I was debating about the ARB twin and trying to mount it back in the back under the bed rails on the pass side.
