Hey guys, the more i look for wheels, the more im seeing beadlocks as a lot of the options i tend to like, now minus the legal issue, does anyone have experience running them? I don’t want to have to keep track and re-torque my wheels once a month, though i heard that isn’t exactly true, what are the downsides?
I like ‘em. Mine are KMC cast aluminum with 3/4” thick rings. 5 years ago, they were pretty innovative, but today, most of the good beadlocks from raceline and innov8 and others are built that way.
Forged is nice, but too expensive for our type of wheeling (not racing). Cast is a good compromise, and gets away from the old style stamped steel stuff that we think of when we talk about leaks.
Downside: they’re expensive, a little heavy, and tires shops are allergic to them.
Upsides are many, and I’ve not had any problems.
@AgDieseler does tons of road miles in his burb with beadlock wheels.
On the high side, I’ve done 12K in a year. I usually drive 65-70 on the highway, but have gone as high as 90. Each trip airs down and up from 5 to 30 about 10-15 times. I’ve rashed the rings pretty good, and everything is still ultra steady, no bad vibes, zero retorques, and tire wear is pretty even for C rated 40s under a 9500 lbs truck.
If you want to air down to single digits, accept no substitutes. But, if you just want to flatten out around 10-12 and you’re not hanging all your weight on one tire on a slick rock ledge, look at bead grips. A few of my friends run them with good results. They seem like a decent value option when you don’t plan to turn your tires into tracks.
David
