this is probably a total newb question but ive always wanted to know...
what is the proper way to put the two nuts and washer on after putting the bearing in the hub of a 10 bolt?! it seems no matter what i do, hand tight, real tight whatever it always backs out on me. i know all about the little nipple on the first nut then getting the washer to slide on it but it still comes loose.
the way i usually do it isthe inside one goes on hand tight, slide the washer on then tighten the outside one kinda tight
