38377k5 said:The pins wouldn't likely make the torsional strength much greater. Most of the torque is taken up by the friction between the two plates, plus the alignment pins are probably too loose of a fit to really take any torque.
I think most stock setups that are like this use a pilot in the middle of them to keep everything centered. Maybe the alignment pins are his replacement for that![]()
nvrenuf said:I see how you used the old yoke, could the same be done with a 205 yoke for the 32 spline crowd?
Stomper said:Yep, he's bound to find the next weak spot
Those joints are stupid beefy![]()
Bingo. You have to have the "light press fit" concentric step. It won't work otherwise38377k5 said:I think most stock setups that are like this use a step in the middle of them to keep everything centered.
cybrfire said:Hopefully the next weak point is traction coefficient, {is that the right word} Pfft. Whatever, When there done and the blazer is ready to roll again, I'm doing a 6000 rpm clutch bomb!![]()
cybrfire said:So far this is not a product so I don't want anybody thinkin' i'm advertising these. At this particular time I'm simply taking advantage of the shop resources for my own rig and sharing the outcome with you guys!
!!CDA 455 said:Wow!
Now, if I only knew what the hell I was looking at!!!
Big91RustyBucket said:I agree , still can't place it.
Big91RustyBucket said:I know what a pinion flange is , but in the pic it is sitting inside a rotor, and I need to see stuff compared to something to understand. Especially when it is in a pic of something that has nothing to do with it![]()
.Big91RustyBucket said:I know what a pinion flange is , but in the pic it is sitting inside a rotor, and I need to see stuff compared to something to understand. Especially when it is in a pic of something that has nothing to do with it![]()
What about the anti-wrap bar was busting u-joints?camok5 said:I dont mind at all if you use my pic. Actually its funny because I'm in the middle of replacing that yoke with a HAD 1410 strap upgrade kit. As you can see in the pic that my old M.O.O. anti wrap bar sucks and has caused me to go thru a handful of 1350 U joints. Might have to give you a call soon for a Wraptor upgrade kit.
blasphemous said:What about the anti-wrap bar was busting u-joints?
