Before & After thread.
The day I aquired it in trade for my '90 K5
4 months ago
Some before pictures...:)
And some after...:D
It's amazing what a new set of rims and tires can do for a Blazer. Taking the top off helps too! :D
ill play. not near as extreme as some. but heres waaaaay back two summers ago when i bought it. chitty six inch lift with 3.08s and a leak from every place possible. i mean every place. trans fluid like Dr. Pepper. distributor plugs two plugs off and stabbed improperly. running rich as hell and muddy water lines under all the trim. wiring a birdsnest and TWO alarms on it, neither working properly. but it came with this really sweet bumper!!
heres the axles getting beutified and geared up:
had to test them right?
heres now with those 456 gears and a limited slip with 37 MTRs. all the leaks fixed and an all new steering system completely. all motor accessories and gaskets are new. nice exhaust and in pretty presentable shape. all new suspension lift with a shackle flip with nice rancho 9000 shocks. new CV driveshaft and soon to have a new 208 put in it. several other minor things taken care of like all the switches do what theyre supposed to and even the back window still works. all the trim pieces removed and painted interior and carpet cleaned. (for mall crawling purposes only) NOS buckets and AC fixed. like a new truck basically. but bigger
ok before bout 2 years or so ago
different front end and tires and wheels
as of right now :D not much has changed
not quite done yet either :D lots more money to spend
one more for the mix
Mine looks damned near the exact same as when I bought it.
Before:
After:
All the stuff that's changed is the small stuff -
ORD bolt-in steering brace; trans cooler; deep trans pan; gutted interior; bunch of new sensors and parts for the engine; new fuel pump; all fluids drained, cavities flushed, and new fluid in; new starter; new alternator; bull bar; and a bunch of other boring little things.
Hopefully she'll be sitting on locked 1-ton axles next year, with new tires. Who knows.
i'd say it looks completely different. you can't even tell that's a side view in the second pic :D haha sorry
i guess i shoulda added i changed it from a 350 turbo to a sm465 and from a 305 to 350 back to 305...don't ask DOH!!
