Looks like a long one to me. Its only about 1/2 difference.
Just checked, same dimensions as the old oneLooks like a long one to me. Its only about 1/2 difference.
Thanks for the help.....great pictures and clean engine! I may have a chance to check it out again tomorrow. It's a new, aftermarket pump from NAPA. Grooves are right size. From your pics, looks like it's a tight squeeze anyway. I'm guessing the pump is just out of spec a bit. I'll get back to you. Thanks again.Are you sure the crank pulley is the right diameter and not to big putting the belt to close to the pump.?
Oh, and I'll check the size of the pulley with yours as a reference too.Thanks for the help.....great pictures and clean engine! I may have a chance to check it out again tomorrow. It's a new, aftermarket pump from NAPA. Grooves are right size. From your pics, looks like it's a tight squeeze anyway. I'm guessing the pump is just out of spec a bit. I'll get back to you. Thanks again.
are you running AC on this. His pulley has a lager front than yoursAre you sure the crank pulley is the right diameter and not to big putting the belt to close to the pump.?
Yes. Just asked my son , who will be driving it, if he wants the top on or off most of the time. He said on. So I want to have the ac available.are you running AC on this.
