Now that you have a belt that fits--write the part # down somewhere on the truck in magic marker,like on the radiator support,so if there is a "next time" any parts store can supply the right belt with no guesswork..
I have had to keep a small notebook in my glove box when I swapped an engine from another vehicle into one of my trucks in order to know what parts they used...like my '81 G-10 van,it had a straight six originally,it now has a 307 V8 from a '73 Chevelle in it (and the radiator from the same car!)...so if I need parts like belts,water pump,etc,I have to look up a '73 Chevelle..
I also keep any unbroken used belts in the vehicle for spares in the event one breaks out in the boonies...ditto for used distributor caps,rotor,coil,ignition module,alternator,starter--doesn't take up much room and they can save your butt if you end up needing them !..
