bent drag link with x-over.... or not.
az-k5
Phoenix AZ
Well that pretty much is my question. I am just wondering pros and cons of each. Specs are as follows.
1979 K5 with a Dodge D60, 4" BDS springs, longer shackles, and 37" MTR's. I am not afraid to cut the x-member. I plan on going up to 40's this summer with a zero rate moving the axle 1" foward and hydro so those mods need to be considered also. The main concern for a strait drag link is the wear on the ends, but I don't like the idea of a bend in my link either cause it seems to be a stress riser. I just need a little input also.
/forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif
Thank you /forums/images/graemlins/bow.gif
PS. Is there a strength difference in the king pin load design between these two??
and big picture so clicky please.
a bent drag link will allow for a lot less bind.
as for the shakerbuilt arm.. i dont like it. they need to have the counter sink holes i feel. keeps everything a bit more snug to the knuckle.
grant
I hae a bent drag link and it still hits the cross member. Not much but it hits. I plan on getting the MOO cross member if I ever get to replacing my engine. I do like the way it lines up though. With the drop, sitting still, the drag link is parallel with the tie rod.
You might want to PM Shaggy about his experience with Shakerbuilt arms before you spend your hard earned money...... /forums/images/graemlins/deal.gif
Fit and Finish on the ORD stuff is always first-rate. I think I own every product they make for my '72! /forums/images/graemlins/woot.gif
I run an ORD steering arm and a bent draglink with 4 " lift. I like it. The only down side at all as far as I'm concerned is the inability to get the Steering wheel perfectly straight. At least I haven't been able to. Although I could probably get it closer by removing one end of the drag link and just turning it.
I'd go with a bent draglink, it won't hurt anything and will give some extra clearance.
The Shakerbilt crossover arms are a complete waste of money, 100% poorly designed and shoddily built garbage.
Yup. I'll have mine finished installing this weekend. Just have to get the new box on and draglink.
Okay, I have decided to go with an ORD arm and I am gonna bend my link. I hope an m-tech can handle 1.5" .250 wall...we'll see /forums/images/graemlins/grin.gif
[ QUOTE ]
[/ QUOTE ]
shaggy could you PM me the details on this? I got the arms off ebay for the wagons hi steer.
[ QUOTE ]
Two words.....
Sky Manufacturing. /forums/images/graemlins/thumb.gif
[/ QUOTE ]
Uh, yeah! I'm pretty sure that I'm the one that introduced the Sky arms to CK5... /forums/images/graemlins/thumb.gif That's what I replaced the crappy Shaker one with, I never even installed it.
Jeremy, I ordered the Shaker arm and it came with the hole for the spring set off to the back of the arm a full 1/4". It wouldn't even physically bolt to the knuckle. Also, the angle that's cut in for the DRE is useless, since it only has an angle milled into it on one side, the top. The hole is drilled through perpendicular to the main body of the arm, not the angled part. So basically the angle is just for looks, it does nothing for function. Hard to explain, suffice to say that it's a crappy design unless he's changed it.
It's also a flame cut arm out of plate steel, and it's the same price that I paid for the full CNC'd Sky arm. /forums/images/graemlins/rolleyes.gif
