I fixed the tow rig model...
Now I'm digging into which trailer is going to work best. I started leaning towards a pierced frame deck over to avoid fenders as seen in the last post. However, I quickly realized the top of the camper AC unit is approaching 13'-5" with a 34" deck height and raising the camper 7" to avoid cutting holes in the deck for the sewer drain. The rear flip ramps also take up cargo space on the trailer with the truck moved forward to allow full operation.
The low deck 102" wide triple axle units are only a 26-27" deck height bringing the overall height back down closer to having the camper on the truck. But I still need a 7" spacer to avoid modifications of the deck for the sewer pipe. But, that make the bumper and landing work for getting into the back of the camper. I am also able to position the CUCV farther back, creating an 8 foot space between the camper and truck for extra cargo.
Now on to the fun part... or the engineering part. I pulled in specs from different trailers and the deckovers also tend to be 2000 lb heavier than the low deck option. I also cannot use the extra capacity over 21K rating with the current 2016 Chevy 3500HD as it is only rated for 21K towing with a gooseneck. If I upgraded the truck later, the newer models are rated higher, but I don't plan to replace this truck in the next decade or possibly longer.
So, focusing on the Lanmar H8 102" x 36', loads look good on the truck axles and trailer up to 3000 lb extra cargo, 1000 lb each location added between the bed of the truck, tool boxes under the camper, and the deck between the camper and CUCV.
