H
Hop-up
Guest
I figure =d I might as well go ahead and get a new carburetor. I was looking at an edelbrock 650, but I've been doing some reading on the Q-jets. Would it be better for my truck especially when off-road? Sounds like the Q-jet is better ?
Here's a description of the rebuilt Q-jet. :
750 CFM late style M4ME electric choke type Quadrajet for 350 engine TRUCK applications. This carb has 73 jets 52M primary metering rods and DA secondary rods, it was assembled using only the highest quality components, it features: All new parts and gaskets including brand new electric choke, new pull-off, float, needle and seat , re-colored castings , brass bushings in the throttle shaft,re-finished base, yellow zinc plating on all linkages and hardware,casting plugs are sealed with epoxy to prevent leak-down into the intake manifold.Base gasket included.
- just defending a carburetor that I love
