1BEATK5
i had my k5 350/350/203 (still full time) 3.08s/35s getting 14 highwy. 60-65mph. i was driving 55 miles each way to work. there are some steep long hills on that highway too.
i spent alot of time tuning the ignition. the biggest bang was an adjustable vacuum advance. tuned it for as much advance as i could get. set the initial at 6 degrees. then started adding more vacuum advance until it started pinging. then backed it off a little.
i also had headers/dual exh/intake/q-jet/rv cam. after i put 42s/4.88s it still gets 10. which i think is really good for a big truck.
my advice for max mpg
tune the ignition
q-jet
headers/exhaust. but not too loud. because then you will get "on it"
lower the truck as much as possible to run the tires size you want
mall terrains or hwy tires
tachometer. my truck never see's 2000rpm before i hit the highway.
dual throttle return springs.
appropriate gear/tire/trans ratio
tune the ignition
q-jet
